Focus Issue
COW Forums : Field Production
simon de Little
Focus Issue
on Oct 16, 2010 at 3:49:33 am
When shooting a wedding recently the lens on my JVC HM700 came loose at a crucial time and the focus on the camera went very soft. I was wondering if there are any plugins or software that can rescue the footage at all? I edit in FCP7.
Fernando Mol
Re: Focus Issue
on Oct 16, 2010 at 4:33:13 am
You can play with the contrast and add some noise to distract from the out of focus, but you will never get your focus back.
Using a sharp filter will probably not work, but give it a try.
I hope this helps
*Always share a link to your site and rate the posts. This is a free service for you and for us.
simon de Little
Re: Focus Issue
on Oct 16, 2010 at 4:59:50 am
cheers.. I'll have a play around. I realise it's pretty hopeless but I thought I'd put it out there in case anyone had designed some magic tool to fix it. You never know!
Scott Rachal
Re: Focus Issue
on Oct 17, 2010 at 1:16:48 am
Depending on how out of focus your footage is, and how much running time you are talking about, try shrinking the footage.
Maybe put a full-bleed, toned picture in the background, and have the footage in question play at 40-70% of full size. As the picture shrinks, it will look more in focus. (Once again-depending on how out of focus it is)
Maybe put two shots on screen at the same time, both reduced in size? Depending on the content...
