HDMI signal from SmallHD not supported by consumer TV
COW Forums : Field Production
Warwick Field ACS
on Jan 30, 2019 at 6:21:35 am
Has anyone had any issues sending a HDMI image from the HDMI output of the SmallHD 1703 monitor to an older consumer TV? I have tested the output and got an image on an Atomos Sumo with HDMI soi there is a signal and the cable is OK but when i connect to a regular TV via HDMI I get Signal Unsupported. I tried two different TV's. The TV's are 1920x1080. The camera signal from Arri is 3.2k but even when I set it to HD no luck. I don't really ever use HDMI so don't know much about it. Has there been a change to the HDMI signal type recently that is incompatible with TV's over 3 years old?
Cheers Warwick Field ACS
Cinematographer
Australia
Jeff Pulera
Re: HDMI signal from SmallHD not supported by consumer TV
on Mar 20, 2019 at 5:38:00 pm
Many or most consumer monitors cannot accept 24p signals for instance since that is not a standard used by broadcasters. 1080i or 720p60 would be acceptable standards in the US that all TVs should handle, can't speak for PAL situations.
Jeff
Jeff Pulera
Safe Harbor Computers
Warwick Field ACS
on Mar 20, 2019 at 11:57:12 pm
Many thanks for your advice Jeff
