What's the Easiest way to create the lightsaber effect?
COW Forums : Field Production
Sa Dilshan
on Jan 17, 2019 at 11:15:53 am
Hi, I want to create a lightsaber effect (one person, tripod shot) . I have a toy saber (without lights.) Problem is I want to create 2-3 minutes videos every week. (dont want to be professional at all) And it takes forever to animate it in AfterEffects frame by frame. Is there any easier way to do this while shooting. So I can save time in AE?
Blaise Douros
Re: What's the Easiest way to create the lightsaber effect?
on Jan 18, 2019 at 7:40:54 pm
Make a really visible track point at both the tip and the hilt of your lightsaber. Use the Point Tracker to track each of these points. And then download this plugin:
https://www.videocopilot.net/blog/2016/03/new-plug-in-saber-now-available-1...
Use the point tracking data to control the Start and End points of the Saber plugin, and then all you have to do is clean it up. You'll still have some hand work to do, but it's much easier than going frame by frame.
Kalleheikki Kannisto
on Jan 22, 2019 at 6:00:11 pm
+ when shooting, use short shutter speed, that way AE will have much better time tracking the track points.
Senior Graphic Designer
Bill Davis
on Feb 12, 2019 at 7:57:29 pm
Darn, just saw this.
FanFilmFX.com is what you need.
It's a totally cool light saber generator. There's a free version and the paid version is only $4.
These are also hosted on FXFactory. So you can get them there with confidence.
Have fun!
Creator of XinTwo - http://www.xintwo.com
The shortest path to FCP X mastery.
Brandon Lanski
on Nov 3, 2019 at 7:20:37 pm
Also, when you're going frame by frame, use the page up and page down keys on the keyboard.
Also you don't need to put a keyframe on each frame, you can probably get away with a lot more than you think you can by doing your first keyframe, placing another maybe 8-12 frames later and then checking in between real quick to see if there's anything that needs to be nudged just a little.
You can download the daber plugin, vrom video copilot. They have an older version too if you want a "shittier" look
Brandon Lanski
on Nov 3, 2019 at 7:21:31 pm
*Saber plugin *From Video Copilot
