Signal adapter / conversion at start or end of cable run?
COW Forums : Field Production
Jason Twite
on Aug 12, 2013 at 7:59:00 pm
Workflow:
Canon XH AI output via HD Component --> BMD Analog to SDI mini converter --> input into switcher via HD-SDI.
Which is the best practice?
A) Have the mini converter right at the camera to go from component out and then make a longer run (100' - 250') of SDI cable to the switcher.
B) Have the mini converter near the switcher and have component cables do the longer run?
Trying to figure out whether I need to buy more component or SDI cables.
