Canon KH21eX5.7 IRSE A 1/2” HDgc Zoom Lens for sale
COW Forums : Classifieds, Retailers
francisco gaviria
on Aug 7, 2014 at 10:17:46 pm
For sale
Canon's KH21eX5.7 IRSE A lens is a one-half inch long length HD zoom lens specifically designed for use with Sony's HD XDCAM cameras, which use three 1/2-inch 1440-element CCD imagers. Optical and mechanical design innovations include special coatings to minimize ghosting, flare, and other optical aberrations caused by strong light sources, and high MTF (Modulation Transfer Function) without affecting the maximum relative aperture throughout the entire zoom range.
FEATURES
Enhanced digital drive unit
Delivers a wide angle of view at 63 degrees, and focal lengths up to 120mm (or 240mm with extender)
High level optical performance
Ideal for broadcast and cable news photographers
SPECIFICATIONS
Zoom Ratio: 21x
Built-in Extender: 2.0x
Range of Focal Length: 5.7~120mm
Range of Focal Length with Extender: 11.4~240mm (2.0x)
Maximum Relative Aperture (with extender):
1:1.4 at 5.7~86mm
1:1.95 at 120mm
1:2.8 at 11.4~172mm(2.0x)
1:3.9 at 240mm (2.0x)
Angular Field of View (with Extender) in 16:9 Aspect Ratio (9.6 x 5.4mm):
62.9° x 38.0° at 5.7mm
3.3° x 1.9° at 120mm
31.5° x 19.0° at 11.4mm (2.0x)
1.7° x 0.9° at 240mm (2.0x)
Minimum Object Distance (M.O.D.): 0.8m (10mm with Macro)
Object Dimensions at M.O.D. (with Extender) in 16:9 Aspect Ratio (9.6 x 5.4mm):
92.2 x 51.9cm at 5.7mm
4.3 x 2.4cm at 120mm
46.1 x 26.0cm at 11.4mm(2.0x)
2.2 x 1.2cm at 240mm (2.0x)
Size (W x H x L): 169.4 x 111.9 x 217.5mm
Weight (Approx): 4.08lbs (1.79kg)
contact.francysfilms@hotmail.com
