FOR SALE: Blackmagic Design Workgroup Videohub
COW Forums : Classifieds, Retailers
Brian Hughes
on Mar 16, 2012 at 6:14:55 pm
We have for immediate delivery this very gently used Blackmagic Design Workgroup VideoHub.
12 Inputs and 24 Outputs, BNC, RS-422 Switching, USB IP Control
We will provide a 60 day warranty with this.
Free shipping in the US only. For international shipping please contact us for a quote.
Please do not not make any assumptions about our listings, rather kindly contact us with any questions and we will answer them as soon as possible.
LOCAL TO NEW YORK CITY AND SURROUNDING AREA. PICKUP AVAILABLE, OR DELIVERY FOR SMALL FEE.
Thank you
The Blackmagic Workgroup Videohub is an SDI Routing Switcher supporting both Standard Definition and High Definition SDI signals. This device offers 12 inputs and 12 outputs with monitoring for each SDI output. Switching is accomplished from a remote computer and the main unit comes in a very user friendly design. This router offers a good control situation for non-linear editors working with multiple formats and machines.
Dual Rate
Modern equipment such as Videohub allows for dual rate switching between standard definition 270 Mbps or high definition 1.485 gbps video rates, so newer HDTV equipment can be integrated into existing systems.
Monitoring
Because most editors love to have "direct from the router" monitoring, Workgroup Videohub has 12 independent outputs totally dedicated for monitoring. Independent monitoring outputs are great when you have more than one person working on a job and you need to quickly look at decks and other editing system in your facility.
IP Control
Video routing switchers are popular in high end post production because they allow non technical people to connect to each other and share broadcast decks, without the complexity of manual cable patching. Remote switching via your IP network means you don't even need to walk to a central patch panel - great when there are many people working on the same client job.
Deck Control Routing
With 12 independent Sony compatible RS-422 serial control ports included, each editing system can control any deck in your facility. Each deck control connection is independently reversible via software control, so it's easy to connect edit stations or decks to any of the 12 deck control ports.
Network Shared Control
Install Videohub anywhere in your facility, because all computers on your network can change connections, or even labels. And, anyone can lock a destination remotely, which is essential when doing important recordings that you don't want interrupted.
Consumer Format Dubbing
Adding consumer grade decks for client dubbing is easy, and you can use any spare output such as one of the SDI monitoring outputs. You can add digital to analog conversion to connect video and audio to VHS and DVD recorders.
Brian Hughes
Broadcast Pros
brian@broadcastpros.com
Mobile 818 461 4121
Office 212 564 4749
Brian Hughes
Re: FOR SALE: Blackmagic Design Workgroup Videohub
on Mar 21, 2012 at 7:35:11 pm
BLACKMAGIC VIDEOHUB SOLD.
Please contact us if you are looking for Blackmagic Design products.
We are a reseller, and will be happy to assist you.
Thank you.
Brian Hughes
Broadcast Pros
Mobile 818 461 4121
Office 212 564 4749
