Panasonic 3700 for sale
COW Forums : Classifieds, Retailers
Michael Shugrue
on May 13, 2011 at 4:22:33 pm
Viewfinder,camera plate included.
AJ-HVF21G Electronic 2" 16:9/4:3 Switchable High Definition Viewfinder
Designed to capture feature films, television episodics and commercials, the AJ-HPX3700 is Panasonic's new workhorse camera producing uncompromising cinematic image quality with the exceptional reliability and faster workflow of solid-state P2 HD.
Recognized worldwide as the industry's premier digital cinematography camera, Panasonic's VariCam HD Cinema Camera has established itself as an indispensable acquisition tool delivering the distinct, prized look of film. As the Flagship model of the new P2 HD VariCam series, the VariCam 3700 ushers in a new solid-state era that features a master-quality codec, maximum image performance, and film-style operability.
Features:
AVC-Intra 100, AVC-Intra 50 and DVCPRO HD codecs
AVC-Intra 100 provides master-quality, 4:2:2, 10-bit, full-raster, native 1920 x 1080 recording
Native 1920x1080 imager
Dual link RGB 4:4:4 output with log response capability and simultaneous 4:2:2 HD record in camera
Offers choice of progressive/interlace HD video formats including native 1080 23.98p/24.00p/25p/29.97p/30.00p, as well as 1080 50i and 1080 59.94i.
Variable frames (1 to 30fps) and 23.98/24psf output (via HD-SDI)
AVC-Intra compatibility with leading NLEs, including Apple Final Cut Pro 6, Autodesk, Avid Media Composer Family Version 3.0, Avid NewsCutter Family version 7.0 and Quantel.
4:4:4 record compatibility, including variable frame rate support with Codex, S-Two and Keisoku Giken
4:4:4 compatible with the Panasonic AJ-HD3700B D-5 HD VTR with AJ-HDP2000 2K Processor.
Scan reverse allows for anamorphic lens adapter use (to create a 2.35:1 aspect image for wide-screen cinematic shooting), or, use an HD lens adaptor for 35mm lenses.
Advanced gamma settings including Film-Rec and P10 Log (Cineon)
14-Bit Digital Processing with 12-Axis Color Correction
High F10 sensitivity at 2,000 lx, Minimum illumination of 0.021 lx (at 1 fps VFR and +30-dB gain-up)
Electronic shutter that offers seven shutter speeds up to a maximum 1/2000 second (plus a Half mode) and unique angle settings (similar to a film camera)
Proxy data recording available (with the optional AJ-YAX800G board)
Five P2 card slots allow for over 6 hours of 1080/24p record time (with five 64GB P2 cards)
Newly-designed grip handle with five threaded holes for mounting accessories and a 3-point locking viewfinder mount for precise adjustment (color viewfinder compatible)
48-kHz/16-bit, four-channel digital audio recording
Multiple system Interfaces, including three HD-SDI Outputs, USB 2.0 and down-converted SD video output
