Brightcast Professional LED Lighting
COW Forums : Classifieds, Retailers
Amy Gao
on Apr 5, 2011 at 7:24:11 am
Brightcast Products Key Advantage
CRI: Color Rendering Index
Most current LED lights have a CRI of 70, which is not suitable for high definition filming. Brightcast offers CRI levels of up to 95!
Variation in CRI and Color Temperature can cause problems when filming with multiple light sources. Brightcast light CRI and accurate CCT avoid color rendition problems.
Drop Guards
Two filter slots for softness, CT and color adjustments. Drop-guards prevent filters from dropping when lights are upside down.
Total Control
Dimming and other adjustments can be performed via:
• Dial
• Infra-red remote
• DMX control
0-100% light regulation is possible for all panels. Color and angle can be adjusted in function-capable lights.
Multi-panel control via DMX.
8+Hours Battery Life
Energy Saving = Money Saving
Energy inefficient lights usually start going dim after 3-4 hours. A standard Sony battery can last up to 10 hours on a Brightcast light, staying on maximum brightness much longer.
Longer Lifespan
Most LEDs will lose CT accuracy or brightness levels after some months.
After less than a year of use, a poorly designed LED product can flicker, shift in color, look dim, offer uneven light, or continue to use power when turned off, among other problems.
Original Picture and Picture After 1 Year Operating
Flicker Free
No beat effect /flicker-free dimming.
• Constant current regulators guarantee stability
• Changing brightness does not change CT
• No flashing in camera screen
Digital Display
Digital display shows brightness and CT. Brightness and CT are regulated separately. Adjusting brightness will not change the CT.
Brightcast's range of broadcasting and professional lights all use the newest LED technology. Energy-saving, high efficiency, long life, no flicker, light weight and portability are standard features. It is also worth mentioning that all Brightcast products offer wireless infra-red controls. Angle, color temperature, and brightness are all adjustable in unlimited network environment. In addition, in order to facilitate the outdoor filming, all products support battery and AC-DC adapter power supplies. Excellent performance means Brightcast products are widely used in studios, theatres, new sites, workshops, conference rooms, classrooms, indoors and outdoors, and many other situations.
