Need advice on fixing awful interview audio with iZotope RX 6
Erik Rosenbluh
on May 8, 2017 at 3:58:29 pm
I was given an interview that was recorded, to put it mildly, gawdawful. I was wondering if there was a way to make it audible? I played with iZotope RX 6 a little, but I'm no sound mixer. I'm hoping someone has some suggestions, or can at least tell me it's a lost cause.
Original:
https://youtu.be/JAQFCcoAiz4
My attempt at cleaning it up:
https://youtu.be/YYWVBehK8SU
Thanks in advance.
Chris Wright
Re: Need advice on fixing awful interview audio with iZotope RX 6
on May 9, 2017 at 4:01:51 pm
ill try it if you post a download link. i'd first do a de-clip, de-reverb, then a de-noise, in that order. then I'd use leveler freqs. or I'd try noise reduction in audition with learn sound model.
then enhance vocal range raising 95hz 2.5 dB Q 2 width, and 972 hz 4.5dB Q2 and 1306 Hz 4 dB 2Q
then multiband compressor
finally
match loudness ITU-R BS.1770-3 -24lufs for correct audio levels
Erik Rosenbluh
on May 9, 2017 at 8:42:23 pm
Which setting would I use to enhance the vocal range raising 95hz 2.5 dB Q 2 width etc?
But if you'd like to give it the old college try, here's a link to an AIFF output.
https://www.dropbox.com/sh/lp2nk3mdq8o8lnz/AACzpVTdCPwT-ra9eX3PsmQ7a?dl=0
Erik
Chris Wright
on May 10, 2017 at 4:38:24 pm
its leveler. do you have the advanced version? it comes with vocal enhancer as well.
what happens when you try my steps? I need to update my rx! i just need 30 sec. audio. 329mb?
