Fostex DC-R302 Stuck in USB mode
Nathan Kendall
on Jun 30, 2016 at 7:49:23 pm
I have a Fostex DC-R302: 3 channel recorder that records to SD card and streams to computer via USB. It currently is stuck in USB mode and I cant seam to reset it.
Ty Ford
Re: Fostex DC-R302 Stuck in USB mode
on Jul 3, 2016 at 1:38:48 am
Hello Nathan and welcome to the Cow Audio Forum.
Power down, disconnect USB cable, take batteries out, hit power button several times, put batteries in, see if it starts without being in USB.
Regards,
Ty Ford
Cow Audio Forum Leader
Want better production audio?: Ty Ford's Audio Bootcamp Field Guide
Ty Ford Blog: Ty Ford's Blog
Nathan Kendall
on Jul 17, 2016 at 5:33:42 am
I did what you said and the device is still in USB audio ready. Pressing menu does nothing. I thought there was a reset combo of something like pressing and hold exit +menu or exit +record. nothing resets to standard mode.
Ty Ford
on Jul 17, 2016 at 4:41:19 pm
OK, reach out to Eric Toline in Florida.
Have you contacted Foster about it?
I suspect they have a master reset as you suggest.
See if he's run into the problem.
audioetc@bellsouth.net
Regards,
Ty Ford
Nathan Kendall
on Jul 19, 2016 at 12:01:09 am
Thanks Ty for that info. I emailed Eric and awaiting response.
Eric Toline
on Jul 19, 2016 at 12:54:10 am
Look here for possible help.
Manuals : Fostex Support
http://www.fostexinternational.com/docs/tech_support/manuals.shtml
All Fostex Products. Model, Owners Manual, Supplement, Other. 160, • Owners Manual ... DC-R302, • Owners Manual Multi Language, • Quick Start Guide.
"I push the RECORD button and hope for the best"
