Possible to split timecode signal from recorder rather than daisy chain?
Joe Bender
on Apr 10, 2016 at 3:27:50 pm
Hi all,
I'm working on a setup where I'm planning to feed timecode from a Zoom F8 to five (5) Atomos recorders. I can save some money by using the Shoguns rather than the Shogun Studios, but they don't have timecode loop-through. Is it possible to split the timecode signal from the Zoom F8 to feed multiple video recorders in parallel? If so, what kind of hardware would I need?
Thanks in advance for your advice,
Joe
Eric Toline
Re: Possible to split timecode signal from recorder rather than daisy chain?
on Apr 10, 2016 at 5:06:02 pm
Remember that a time code signal is square wave audio not video. You can split it just as if it was a standard audio signal. From the TC out BNC connector on the F8 you can use any number of BNC splitters/adapters with no problem. You may need a TC amplifier to keep the TC signal at optimum level.
"I push the RECORD button and hope for the best"
Joe Bender
on Apr 13, 2016 at 4:19:01 pm
Thanks Eric, sounds good. Don't think I'll end up having this problem on my current shoot but will use this technique in the future.
