What is DME track and why is it needed
Mike Thomas
on Mar 15, 2016 at 12:23:21 am
If a distributor asks for a DME audio track for your movie they're distributing what exactly are they expecting and why do they need it?
Eric Toline
Re: What is DME track and why is it needed
on Mar 15, 2016 at 1:17:19 am
DME is the Dialog, Music, Effects track. They might want those tracks to do a remix for whatever reason.
"I push the RECORD button and hope for the best"
Mike Thomas
on Mar 15, 2016 at 2:00:57 am
THanks for the help. Making 3 separate tracks makes sense. I was confused because it's called "a" DME track...as in one track.
Brian Reynolds
on Mar 15, 2016 at 3:14:42 am
DME... I would have thought that would be the final mix track if it is going to a distributor.
Many years ago a company I worked for was asked for a full mix copy as well as a M&E copy, which we did. Only to find out sometime later that that had been used for a 'pirate' copy in a different language (there were NEVER any royalties paid to the producers).
So if you have been asked to supply components or split tracks for a production assume some one wants to change things..... WHY?
ALWAYS assume there is something underhanded going on.
'Celebrating 40 years of Broadcasting Audio....
Started with Magnetic stripe and Sprocket holes to now Gigabytes and Touch Screen Mixing Consoles'......
