OMF files why are they asking for aif's?
Larry Watts
on Jan 18, 2016 at 7:56:30 pm
I have not worked with OMF' before and I plan on purchasing protools in Feb.
I need to start working with these now and all I have is logic and audition.
I attempted to open these with logic, but it said file not found and referenced an aif file.
I thought OMF's where standalone.
THX Larry
Ty Ford
Re: OMF files why are they asking for aif's?
on Jan 19, 2016 at 2:45:32 am
Hello Larry and welcome to the Cow Audio Forum.
Does this help?
https://www.quora.com/Can-I-work-with-OMF-files-in-Logic-Pro-to-do-audio-po...
Regards,
Ty Ford
Cow Audio Forum Leader
Want better production audio?: Ty Ford's Audio Bootcamp Field Guide
Ty Ford Blog: Ty Ford's Blog
Peter Groom
on Jan 19, 2016 at 1:10:33 pm
It depends on how the OMF has been made. You can choose to embed (normal) where the actual audio files are Muxed into the OMF or you can store them separately - In 20 years using OMF ive never had, or made one this way, but i know you can.
OMF is very much on the way out as it is old tech. Now an .aaf is the replacement that does the same, but carries a lOt more metadata etc with it.
Have a look at the .omf file size. If its only a few kb then it has no embedded audio. If it is much bigger, then it has.
Peter
Post Production Dubbing Mixer
