Merge Audio into .mov Files
Janis Huber
on Jun 23, 2015 at 9:41:53 am
Hi there
On the current project I would like to 'bake' the Audio right into the .MOV (2K Alexa) using
the time code. So far I tried to use BF_QT Merge, but it doesn't really do the job. Do you
know any other software where you can synch the Audio right into the quick time file?
I don't really want to do it in Premiere, cause you have to merge
clips (changes names of the clips) to synch by time code.
I hope my question is understandable.
Ty Ford
Re: Merge Audio into .mov Files
on Jun 23, 2015 at 1:46:16 pm
Hello Janis and welcome to the Cow Audio Forum.
If the duration of the video and audio are exactly the same, you can use Quicktime 7 Pro to delete and add audio files.
There's probably a handier way to do it, but I haven't had to figure that out.
Ty Ford
Cow Audio Forum Leader
Want better production audio?: Ty Ford's Audio Bootcamp Field Guide
Ty Ford Blog: Ty Ford's Blog
Bouke Vahl
on Jun 24, 2015 at 1:13:53 pm
Since I'm the developer of BWF_QT merge, what does not work?
Do note, there was some Alexa firmware that made the files write protected, so you could not insert in them.
But that was a couple of years ago.
Do mail me direct if you like, you're entitled to support.
smart tools for video pros
© 2018 All Rights Reserved
