Sound devices 302 TA3 out to camera (wireless)
Alex Grassi
on Feb 27, 2015 at 10:54:45 pm
Hello to everyone!
I am trying to figure out the best and efficient way to send a stereo mix down from the mix out of a 302 (TA3) to a camera in through wireless.
Would that be possible with a single wireless system (transmitter and receiver)?
If not, would that be worthy to modify the TA3 circuit in a way to have a mono summed mixdown (as I would use it as a reference/backup only)
Thanks a lot for a reply!!!!!!
Alex Grassi
http://alterale.wix.com/alexgrassi
alterale@yahoo.co.uk
+44 7707 698983
Ty Ford
Re: Sound devices 302 TA3 out to camera (wireless)
on Mar 1, 2015 at 9:28:42 pm
Hello Alex,
Unless you have two channels of wireless, you can not transmit in stereo.
Regards,
Ty Ford
Cow Audio Forum Leader
Want better production audio?: Ty Ford's Audio Bootcamp Field Guide
Ty Ford Blog: Ty Ford's Blog
Alex Grassi
on Mar 1, 2015 at 9:36:35 pm
Hi Ty,
Thanks for the response!
Alex
Alex Grassi
+44 7707 698983
Eric Toline
on Mar 4, 2015 at 1:38:06 am
The TA3 mix out is a 2 channel summed (mono) mix from the 302. Wire the feed from the 302 to your wireless transmitter with both pins 2 & 3 of the TA3 connected to your transmitters microphone input connector. Be aware that the mix out is a line level feed and could be to hot for a mic level input. Some transmitters will allow switching the tx mic input to line level by connecting the incoming audio feed to a different pin in the tx connector.
"I push the RECORD button and hope for the best"
