Receiver (Audio Frequency) on Sennheiser G2 EK 100
Adrien Thelin
on Feb 23, 2015 at 2:22:58 am
Fundamental question for you gentlemen.
Why are the AF levels on the receiver measured in db (-30, -24, -18, etc.)? When AF is measured in Hertz?
Thank you.
Richard Crowley
Re: Receiver (Audio Frequency) on Sennheiser G2 EK 100
on Feb 23, 2015 at 7:25:05 am
As you said, audio LEVELS are measured in db (deciBels) or volts (or millivolts).
But audio FREQUENCY is measured in Hz (Hertz).
If you look at those on (for example) a frequency-resposnse graph, typically the X-axis (horizontal) dimension is frequency in Hz, and the Y-axis (vertical) is measured in dB.
