Sennheiser wireless - can I send from a laptop?
Tony Pascal
on Sep 16, 2014 at 7:54:05 pm
I have a set of Sennheiser ew100 G2 wireless microphones. I have a belt pack and a camera mount receiver.
What I am wondering about is, can I connect the transmitter up to a laptop's headphone jack and the receiver up to a self powered speaker that is about 100 feet away?
Has anyone ever done anything like this?
Brian Reynolds
Re: Sennheiser wireless - can I send from a laptop?
on Sep 16, 2014 at 10:49:33 pm
It would be quite easy to do..... BUT you will need a custom made cable, I doubt if an 'off the shelf' cable would work.
You will need to mix L+R from the laptop PC and that needs to go into the Sennheiser Tx unit in the 'line in' position (the diagram of the connections is in the Sennheiser manual) If the signal is fed into the 'mic level' input you will get LOTS of distortion because of the signal overload.
The custom cable will look identical at each end but it will NOT be reversable, the plugs will need to go the right way around.
Ty Ford
on Sep 17, 2014 at 2:46:56 pm
Hello Tony and welcome to the Cow Audio Forum.
Eric Toline in Florida can make you the cable you need for this.
(954) 255-7628
audioetc@bellsouth.netRegards,
Ty Ford
Cow Audio Forum Leader
Want better production audio?: Ty Ford's Audio Bootcamp Field Guide
Ty Ford Blog: Ty Ford's Blog
