Rode NTG-2 Issue
David Jones
Rode NTG-2 Issue
on Sep 16, 2014 at 7:53:22 pm
Greetings,
I seem to be having a problem with the Rode NTG-2 mic. It sounds good when phantom powered, but when I use the internal AA battery I get a nasty, static sound (in addition to the audio). I've tested two of these mics with different recorders, inputs, cables, batteries. They both have the same issue. Am I missing something or do I just have two bad, brand new mics?
DCJ
Bob Kessler
Re: Rode NTG-2 Issue
on Sep 17, 2014 at 12:12:32 am
Are you sure that the external phantom power is OFF when using the internal phantom power?
Peace,
Bob
____________________________________________________________________
Filmmaking is the art of the invisible;
If anyone notices your work you haven't done your job right.
David Jones
Re: ode NTG-2 Issue
on Sep 17, 2014 at 4:04:56 am
After further testing, it seems that if I switch from phantom power to mic (turning phantom power off) I get that noise. However, it does fade away after about 2 minutes. As long as I don't switch back and forth between the two it's fine.
DCJ
clyde villegas
on Sep 19, 2014 at 11:03:54 pm
Hi David. Just curious, what audio recorder are you using with the NTG-2? Thanks!
ut in omnibus glorificetur Deus
David Jones
on Sep 20, 2014 at 1:53:23 am
I'm using the Sound Devices 633. However, I got the mic to use as an on-camera mic with the Blackmagic 4K camera.
DCJ
clyde villegas
on Sep 20, 2014 at 2:18:19 am
Thanks for the info, David.
