Right Frequency Lav
Mike Damian
Right Frequency Lav
on Apr 25, 2014 at 5:38:17 pm
I'm looking to invest into a Sennheiser ew 112-p G3 wireless lav. There are 3 versions, with 3 different frequency ranges. How do I know which one to get? I live in Phoenix, AZ and that's were I will mainly be using it. I looked up my zip code on Sennheiser's frequency finder but I don't understand the results it came up with.
Here are the 3 choices.
A/516-558 MHz
B/626-668 MHz
G/556-608 MHz
Craig Alan
Re: Right Frequency Lav
on Apr 26, 2014 at 10:34:04 pm
click on HELP under RESET it will explain chart.
also keep in mind:
the FCC is currently considering auctioning off the 600MHz - 700MHz range which could happen as early as 2015.
470 - 600 MHz should, for now, be future proof.
any time you use a cordless kit you need to do a sound check to make sure something in the air is not causing problems. The unit has a built in scan function to help you find a free channel. Some times nothing works and you need xlr backups.
Mac Pro, macbook pro, Imacs (i7); Canon 5D Mark III/70D, Panasonic AG-HPX170/AG-HPX250P, Canon HV40, Sony Z7U/VX2000/PD170; FCP 6 certified; FCP X write professionally for a variety of media; teach video production in L.A.
© 2018 All Rights Reserved
