Problem with SoundDevices MixPre-D
Juan Luis Gomez
on Apr 6, 2014 at 10:22:15 am
I have just received this great little mixer for sound recording... And It's driving me crazy because I don't know how (maybe I just pressed some weird front panel button shortcut or something) but the only thing I can make of it is turning the "return signal led" on.
This is probably me being a mere idiot because I am a video oriented guy. Anyway, when I turn on the mixer powered by two internal batteries the only led light working it's the "return signal led" instead of the "led above the power switch".
I have tried to set up a pair of shotgun mics (NTG-2) supplying and not supplying them phantom power from the mixer but the led vumeters doesn't turn on and there is no input signal in any case. I have tried it with the tone oscillator as well with the same result: nothing.
I have just written to SoundDevices technical support but, as I said, this is driving me crazy and I guess it has an easy solution that I can't figure it out so I wanted to check here if anyone has a solution before they write me back.
Can anyone help me with this weird personal problem?
Sorry for my english, it's not my mother language.
Nigel Francis
Re: Problem with SoundDevices MixPre-D
on Dec 1, 2014 at 2:06:48 am
Did you fix this? My MixPre-D is not working. I only have power and nothing else, no tone, no slate mic, nothing.
© 2018 All Rights Reserved
