battery power for a SD 664
Larry Watts
on Jan 14, 2014 at 2:38:42 am
I need a field power supply for the SD 664. It eats regular AA batteries very quickly.
Obviously I'd like a reasonable price for a decent product. Mid price point. not the cadillac, but not the cheapest either. "You get what you pay for"
I've read of:
Global Media Pro
Advice welcome!
John Fishback
Re: battery power for a SD 664
on Jan 14, 2014 at 7:03:08 pm
Why not the XL-WPH3, the SD accessory power supply.
MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7
Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
Stephen Benassu
on Jan 16, 2014 at 2:09:36 am
I use IDX 14V Lithiums. I have 2, and 1 batt. usually gets me through a 10 hour day running my 644, 2 Lectrosonic 411 receivers, and a phantom powered boom. You'll nee a cup to attach to the battery, and a power cable for the mixer. Check out Trew audio for all these parts, or Location Sound in LA.
The battery is about $200 and the cup and cable probably $150. (guestimating!) The charger for IDX is another expensive item. My set up includes a power distribution block with 6 outlets to power mixer, radio receivers, and whatever else I might need depending on the shoot. This set up seems to be pretty standard in my world of ENG bag work. Hope this helps.
© 2018 All Rights Reserved
