m audio Flying Cow D/A audio level
Eric Chase
on Jun 5, 2013 at 9:43:03 pm
I'm going from AES digital signal -20db out, and the analogue volume level XLR out put is 4-5db weaker in volume. it's the same on all versions.
yes, I've tested out the AES signal against a digial deck and it works fine. it's only the Flying Cow that seems to cut the volume slightly from a perfect 0db output.
Anyone know how to fix this?
Eric
Ty Ford
Re: m audio Flying Cow D/A audio level
on Jun 5, 2013 at 10:34:50 pm
Hello Eric and welcome to the Cow Audio Forum.
Is there any possibility that you are using an unbalanced cable to whatever metering you're seeing the reduced level on? A malfunctioning balanced cable with only one working signal leg would drop about 6 dB.
Regards,
Ty Ford
Cow Audio Forum Leader
Want better production audio?: Ty Ford's Audio Bootcamp Field Guide
Ty Ford Blog: Ty Ford's Blog
Eric Chase
on Jun 6, 2013 at 3:14:43 pm
For sure it's a balanced cable. I've also tested the cable with other equipment.
Ty Ford
on Jun 6, 2013 at 4:17:50 pm
Eric,
My guess is it's a calibration issue or a level issue.
I'd suggest contacting the mfgr.
Regards,
Ty Ford
