Recorder for Rode Lavalliers
Paul Forte
on Jun 5, 2013 at 1:51:04 am
Forgive the newbie question.
I have a Rode Lavalier Microphone and I'm a little confused as to which recorder I can use. In my mind this combination works:
Lavs> Micon 5 XLR> Tascam DR100
Is this correct? Is there a reason this won't work, such as phantom power issues. And what about the Micon 2 1/4" adaptor? Is it possible to just plug this into teh Tascam?
Ty Ford
Re: Recorder for Rode Lavalliers
on Jun 5, 2013 at 2:58:56 am
Hello Paul and welcome to the Cow Audio Forum.
"The MiCon-5 is designed to connect to a standard 3 pin XLR, with P48 phantom power."
"When using a condenser mic that requires phantom power, set the +48V switch to ON."
The above sentences are from online info about the mic and recorder. Any questions?
Regards,
Ty Ford
Cow Audio Forum Leader
Want better production audio?: Ty Ford's Audio Bootcamp Field Guide
Ty Ford Blog: Ty Ford's Blog
Paul Forte
on Jun 5, 2013 at 4:38:56 am
Thanks for the reply. That's what I thought, but for what ever reason my set up isn't working. Not sure if its the Digital recorder, the Micon or the lavs.
Ty Ford
on Jun 5, 2013 at 12:12:13 pm
Paul,
Use the process of elimination to get to where you want to be. Try another condenser mic that requires 48 V DC Phantom Power.
Read the manual to see if there's a switch in the wrong position.
Regards,
Ty Ford
