Tascam 60D - can't turn off mics
Jim Cunningham
on May 10, 2013 at 12:30:10 pm
I've recently purchased (B&H) the Tascam 60D to use w/ a DSLR. Many nice features, however I've plugged in several microphones (both phantom & non phantom), and can not turn the volume off using the front pots. With the pots completely off, I'm still getting signal in the recordings. The pots seem to kick in at about 11 o'clock. I spoke to Tascam, and was told that was the way the pots work! This means that all mics plugged in are always somewhat live, even if potted off! Admittedly, I've only had the unit for a few days, and could be missing something. The audio level issue feels like an AGC, but I don't see that as an option in the menu.
Any insights would be welcome.
Eric Toline
Re: Tascam 60D - can't turn off mics
on May 11, 2013 at 12:03:35 am
That's because they are not full attenuators only trims with in a range. A big design mistake on Tascams part if you ask me. I wonder how they can justify that?
Eric
"I push the RECORD button and hope for the best"
Eric Toline
on May 11, 2013 at 1:14:34 am
This from a Tascam source:
REC MODE Menu
REC Mode : 4 CH
CH1/2 IN -> STEREO / CH 1 Mute / CH 2 Mute
or ...
Mixer - LEVEL = 0 -> Camera Out would not contain that signal.
I hope this helps.
Eric
Jim Cunningham
on May 12, 2013 at 5:57:30 pm
It does.
