Audio has an echo
Gina Miller
Audio has an echo
on Dec 20, 2012 at 4:11:08 pm
I've got an audio narration that has an echo on it. I've been trying to get rid of it for the last three days, Can anyone help... Thank you
Brian Reynolds
Re: Audio has an echo
on Dec 20, 2012 at 10:37:35 pm
Is the 'echo' slightly before the voice (a common problem with some analogue tapes) or is the echo actually room noise or a poorly recorded voice or has it been artificially been put there, is the track a stereo or mono track?
Is there any chance you can post some on line so we can have a listen.
Gina Miller
on Dec 20, 2012 at 11:24:05 pm
Brian, I tried to put it on here but it didn't work - can I email it to you?
Richard Crowley
on Dec 21, 2012 at 3:45:41 pm
Post your sample on a public file-sharing website and post the link here. Without hearing the sample, we can offer only wild speculation. Don't get your hopes up that the problem can be fixed in post-production editing.
Mark Spano
on Dec 20, 2012 at 10:39:33 pm
Can't do a lot for that problem. I can suggest a plugin that has sometimes helped but with limited expectations.
SPL's De-Verb
Peter Groom
on Dec 21, 2012 at 9:32:20 am
Id not expect much joy with this unless its something basic like 1 leg has slipped to the other and youre listening to a LR stero file in mono. That whould be easy, but if it is truly on the same recording then youll need a re voice.
At least a vo is re doable, not like a shoot etc.
If its been supplied to you externally then just reject it and get the supplier to sort it if its his problem.
Peter
Post Production Dubbing Mixer
Peter Groom
on Dec 22, 2012 at 9:43:07 am
A tick has appeared by my last post.
Was that really it?
Peter
