LUFS and Lex(m)
Grzegorz Kwiatkowski
LUFS and Lex(m)
on Dec 7, 2012 at 9:42:47 am
Do you know if there is any VST plugin that measures LUFS and Lex(m)? There is The Waves WLM Loudness Meter plugin but it costs 400$.
Peter Groom
Re: LUFS and Lex(m)
on Dec 7, 2012 at 5:19:06 pm
have a look at NUGENs VisLM and lc
Post Production Dubbing Mixer
Jean-Christophe Boulay
Re: LUFS and Lex(m)
on Dec 10, 2012 at 9:14:08 pm
I second Peter's suggestion. VisLM-C does a great job, is widely compatible and is cheaper than most other options. Plus, Nugen really have established themselves as the broadcast metering and limiting specialists and they closely follow each standards revision. Updates are online days after revision at the most, not weeks as with some other developers. Most other options are expensive, have limited compatibility depending on software versions or imply that you're already drinking the developer's authorization kool-aid.
The VisLM-H version has histogram metering and data logging facilities the VisLM-C version lacks but, in my experience, The Compact version more that enough for almost all situations.
IHTH
JC Boulay
Technical Director
Audio Z
Montreal, Canada
http://www.audioz.com
Re: LUFS and Lex(m)
on Dec 13, 2012 at 12:04:14 pm
But Nugens VisLM-H doesn't measure Leq(m), does it?
Chris Conlee
Re: LUFS and Lex(m)
on Apr 1, 2013 at 7:20:55 pm
Did this ever get answered? I too am curious whether VisLM does Leq(m) metering. Also, does LM-Correct do Leq(m) corrections?
Chris
