Blue Yeti Pro USB Mic - Can't change sample rate on my Macbook Pro Retina
Jesse Selwyn
on Dec 7, 2012 at 1:35:17 am
Not sure if this is the right place for this post, but...
I've got a Blue Yeti Pro USB Mic which is capable of 'sampling rates from 22kHz to 192kHz.'
The place to change this setting is in Utilities --> Audio MIDI Setup.
There's a dropdown menu there that let's me change the sampling rate (set to 44.1 Hz by default).
However, anytime I select any different rate (48, or 192, or whichever), it reverts back to 44.1 after about two seconds. I can't seem to get it to stick to anything but 44.1.
Could this that my stock sound card is limited to 44.1 Hz?
I'm running a new Macbook Pro Retina, 2.6 GHZ Intel Core i7.
Any ideas? Thank you for the help!
