552 to PC. Again!
Aidan Clayton
552 to PC. Again!
on Jul 30, 2012 at 9:57:49 pm
Hi all, first off, thanks for answering my previous dopey questions so quickly. I am now wanting to set up the 552 to the PC for Mic input to Audition CS6 through the 552. Which is the best way of getting the signal from the 552 to the PC?
Aidan
Brian Reynolds
Re: 552 to PC. Again!
on Jul 31, 2012 at 12:16:15 am
Does your PC have a 3.5mm line input if so use the 'tape out' 3.5mm socket on the 552 to your PC. NOTE this socket has a fixed O/P level and can't be adjusted to mic level [I'm assuming that because my SD442 is like that].
If not you might need to go from the TA3 or XLR sockets switched to mic level with custom made cables.
Or failing that there are lots of converters out there that will convert an analogue signal to USB that might be suitable.
Peter Groom
on Jul 31, 2012 at 11:15:02 am
3.5mm analogue jacks.!
Thats the sort of thing that wakes me up in a cold sweat in the middle of the night.
Than cannot possibly be how its best done from a pro device.
Peter
Post Production Dubbing Mixer
Ty Ford
on Jul 31, 2012 at 12:36:18 am
Hello Aiden,
Why not record on the 552 and transfer to the PC? I'm guessing the 552 has a better A/D converter than your PC.
Regards,
Ty Ford
Cow Audio Forum Leader
Want better production audio?: Ty Ford's Audio Bootcamp Field Guide
Ty Ford Blog: Ty Ford's Blog
Aidan Clayton
on Aug 3, 2012 at 7:59:49 pm
I wanted to record directly in Audition CS6 for a project so need to get a signal from 552 to the PC.
Ty Ford
on Aug 3, 2012 at 8:33:23 pm
OK Aiden,
That's not a standard request, but start looking for whichever hardware box you want that'll take a line input and convert it through USB or available firewire.
If mono is all you need, and the 552 has a balanced mono mic level output, get a Centrance Mic Port Pro.
http://www.centrance.com/products/mp/
Do you need two channel mono or stereo
Ty Ford
