Soundboard to Zoom H4n: Attenuator or DI Box?
Michael Koehler
on Apr 4, 2012 at 12:40:19 am
I soon will be recording a live event by (1) taking a feed from the soundboard into the Zoom H4n's inputs, and (2) using the H4n's internal mics to capture the PA mix from the "sweet spot" of the room. I then can mix these tracks together in post.
Regarding the feed from the soundboard into the H4n's inputs: I have read that it is necessary to use either an attenuator, such as the Shure A15AS, or a DI Box, such as the Behringer D120, to "bridge the gap" between a soundboard's professional line-level output (+4dBu) and the H4n's consumer line-level input (-10dBV). As I understand it, both "in between" solutions are also useful for "converting" a line-level output to the H4n's mic-level XLR input.
Are these assumptions correct? And if so, what are the advantages and disadvantages of each approach? Is it better to use an attenuator or a DI Box to get the job done?
Elliott Klein
Re: Soundboard to Zoom H4n: Attenuator or DI Box?
on Apr 4, 2012 at 4:54:48 am
have a read of this. it's a set up someone uses connecting their field mixer to their H4n using an attenuator. maybe this might work for your situation?
http://www.danmccomb.com/posts/987/connecting-zoom-h4n-to-sound-devices-mix...
Michael Koehler
on Apr 5, 2012 at 3:24:40 pm
Mm, an interesting setup! Thanks for the link, Elliott.
