Product Advice for Switching Audio Outputs
Kesten Migdal
on Jan 5, 2012 at 6:16:57 pm
I'm constantly reaching in the back of my Mac Pro to switch between headphones and external speakers. I also have different input devices such as a DirecTV box and an audio preamp I use with Logic Pro. Should I just get a few simple 3.5mm male to female extension cables, or are there some sort of switching devices that I can leave on my desk?
Thanks in advance for your help.
John Fishback
Re: Product Advice for Switching Audio Outputs
on Jan 5, 2012 at 6:50:41 pm
If it's a fixed position a small patchbay would work. Also, if you Google there are probably switch boxes of various inputs/outputs available. Checkout http://www.Markertek.com.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
Kesten Migdal
on Jan 6, 2012 at 12:01:59 am
Excellent, I'll check out your suggestions. Thanks!
Ty Ford
on Jan 6, 2012 at 3:52:00 am
Hello Kesten and welcome to the Cow Audio Forum,
Why are you switching outputs jacks on the Mac? Why not assign them from the Audio/MIDI panel?
Now for the inputs.What are you plugging in where?
Regards,
Ty Ford
Cow Audio Forum Leader
Want better production audio?: Ty Ford's Audio Bootcamp Field Guide
Brian Reynolds
on Jan 6, 2012 at 7:09:38 am
There are several units around for editing systems... one of these might suit your needs.
http://www.mackie.com/products/bigknob/
http://www.samsontech.com/samson/products/processors/c-class/ccontrol/
http://www.behringer.com/EN/Products/MON800.aspx
The difference between Knowledge and Wisdom is... Knowledge is the knowing of facts.... Wisdom is the sensible application of good quality knowledge...
Kesten Migdal
on Jan 6, 2012 at 8:18:39 am
Thanks! I'm going to give the Behringer a try. Price is right at $65.
Craig Alan
on Jan 8, 2012 at 12:46:36 am
The mac pro has two headphone out ports (front and back) and an optical digital out port.
OSX 10.5.8; MacBookPro4,1 Intel Core 2 Duo 2.5 GHz MacPro4,1 2.66GHz 8 core 12gigs of ram. GPU: Nvidia Geoforce GT120 with Vram 512. OS X 10.6.x; Camcorders: Sony Z7U, Canon HV30/40, Sony vx2000/PD170; FCP 6 certified; write professionally for a variety of media; teach video production in L.A.
