sennheiser ew100 g2 - bad results
Phil Sheldon
on Dec 23, 2011 at 12:01:40 pm
i got the above clip mic system a few years ago and have never got good results from it. the recording has always been distorted and scratchy.
consequently it was put away and has been gathering dust, but i potentially need it working properly in the new year.
i had tried resetting everything but no difference, so was wondering if anyone else has had issues with these.
all the cables look fine but could it be worth trying to replace the mic
any suggestions gratefully recieved
merry christmas!
Phil
Ty Ford
Re: sennheiser ew100 g2 - bad results
on Dec 23, 2011 at 2:01:51 pm
Hello Phil and welcome to the Cow Audio Forum.
The Sennheiser G2 is an entry level workhorse. Proper use does require some knowledge. Mic sensitivity settings, receiver level settings, frequency settings, lav placement, all come into play. In effect, you are operating a miniature radio station.
Perhaps you could post a link to a section of problem audio.
Regards,
Ty Ford
Cow Audio Forum Leader
Want better production audio?: Ty Ford's Audio Bootcamp Field Guide
Phil Sheldon
on Jan 4, 2012 at 1:33:05 pm
hi there Ty
thanks for replying. works been closed over christmas so have only just got back to this.
i'll get the units up and running and get some audio recorded as soon as possible
cheers for now
Phil
John Fishback
on Jan 12, 2012 at 9:50:42 pm
Somewhere on Sennheiser's site is a way to check your area for interference on the freqs your mic uses.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
