Batch processing
David Larsen
Batch processing
on Dec 23, 2011 at 2:32:23 am
Does anybody know of an audio editor or DAW that supports both batch processing and VST plugins?
I have 126 audio files that I need to process. Basically I just need something that will open all the files, run them through a couple of VST plugin effects and save them back with the original file name.
Richard Crowley
Re: Batch processing
on Dec 23, 2011 at 2:41:51 am
I have found Adobe Audition to be very convenient for doing batch processing. I don't have specific experience with using VST plugins with batch, however.
Alain Koffi Sessi
on Dec 23, 2011 at 5:44:16 am
Hello David
IK Multimedia's T-Racks 3 will do the trick. Just to make sure I was not off the mark, I loaded about 20 SFX files into it, used one of the presets, and just batch-processed all the files. It worked well. Other in-the-box mastering solutions such as Wavelab may also work. However, I can only speak for T-Racks 3. I hope this helps.
Alain Koffi Sessi
Sound Designer
