Zoom H4+ XLR adpater+Azden lav = NO SOUND...what gives?
john sklba
on Nov 19, 2011 at 5:53:22 pm
Hello, thank you all for reading my post.
I bought the Zoom and love it. I also own the Azden WLX-PRO Camera Mountable VHF Wireless Lavalier System. This system works with 1/8" Mini outputs, not Zoom friendly, so I bought an Rode VXLR 3.5mm Mini Jack to 3-Pin XLR Input Connector. When I plug either the system or the mic into the converter connected to the Zoom, no sound no matter what I've tried. Can anyone help me out here as to what I am doing wrong? Please?????
Ty Ford
Re: Zoom H4+ XLR adpater+Azden lav = NO SOUND...what gives?
on Nov 20, 2011 at 3:37:01 am
Hello John and welcome to the Cow Audio Forum.
The Rode. Is it the VXLR?
Does the Azden work plugged in elsewhere?
Try plugging a mic in to the zoom. If it works.
It's either the plumbing (incorrect connections) or a bad piece.
Regards,
Ty Ford
Cow Audio Forum Leader
Want better production audio?: Ty Ford's Audio Bootcamp Field Guide
Eric Toline
on Nov 20, 2011 at 6:40:50 am
Bet the VXLR is set up as a "balanced" or Tip, Ring, Sleeve connection and the wireless sends out an unbalanced Tip, Sleeve feed. What you need is a cable with a 3.5mm plug wired tip sleeve to an xlr-m wired unbalanced.
Contact me at audioetc@bellsouth.net and I'll show you the line of custom cables I make for just such issues.
Eric
