No audio when using NTG-1 with Sennheiser G3 wireless
Kadshah Nagibe
on Nov 10, 2011 at 6:15:17 pm
I don't hear any audio when I plug in my Rode NTG-1 microphone to my Sennheiser (SKP) transmitter. The receiver end is fed to a Zoom H4N. Everything works fine when I use my Shure sm57 mic but can't hear any audio when using my NTG-1 unless it is plugged in via cable directly into my Zoom. I tried off, +24v and +48v within the H4N settings but that didn't help. Any idea what's going on?
thanks!
-kaj
http://sweetproductionmedia.com
Stephen Hall
Re: No audio when using NTG-1 with Sennheiser G3 wireless
on Nov 10, 2011 at 7:15:15 pm
The NTG-1 doesn't have the option for battery power - the NTG-2 does. The Sennheiser transmitter doesn't supply phantom power. You'll need an inline adapter for that, or a mic that is battery powered.
Good luck !
Stephen H
Kadshah Nagibe
on Nov 10, 2011 at 7:39:44 pm
that's what i thought. What kind of inline adapter do I need?
At some point I plan to get a Sound Devices MixPre-D Compact Field Mixer would that help to boost the signal and get it to work?
-kaj
Eric Toline
on Nov 10, 2011 at 8:57:28 pm
A Behringer PS 400 48v phantom adapter for about $20 will do the job. Do a search for "48 volt phantom power adapters".
Eric
Kadshah Nagibe
on Nov 11, 2011 at 6:38:52 am
thanks eric but for me the adapter is too cumbersome but for $20 it is a good solution.
-kaj
Brian Reynolds
on Nov 10, 2011 at 10:27:36 pm
There would be several different ways to go....
1. Buy a phantom power adapter to supply the mic with power before it goes into the TX unit. But this adds extra things and can be cumbersome and often not a neat set up.
http://www.bhphotovideo.com/buy/Phantom-Power-Supplies/N/4294240039
2. Upgrade the Sennheiser plug in TX unit to a SKP 200 or SKP 300 as these units will supply phantom power. The SKP 100 doesn't supply phantom (which you have)
http://www.sennheiser.com/sennheiser/home_en.nsf/root/professional_wireless...
3. Get a different mic to plug onto your SKP 100. If you already have a Rode NTG1 buy a Rode NTG2, this will give you an extra mic for your kit as well. Many mic manufacturers produce a battery powered short shotgun mic. ie. Rode, Sennheiser, Beyer Dynamic, Audio Technica, AKG, Sony.
Getting a different mic is often a better option than converting what you already have. The $$$ may not be much different in the end.
The difference between Knowledge and Wisdom is... Knowledge is the knowing of facts.... Wisdom is the sensible application of good quality knowledge...
Kadshah Nagibe
on Nov 11, 2011 at 6:37:08 am
thanks Brian but I already have the SKP 100 plug-on transmitter it came with the kit (100-P series evolution wireless G3)and it doesn't work with my Rode but it works fine with my Shure mic. You're right an adapter would be too cumbersome. I was thinking of either selling the NTG-1 and buying the NTG-2.
-kaj
Kadshah Nagibe
on Nov 11, 2011 at 6:41:05 am
sorry i get it i think you meant 2000 and 3000:-)
-kaj
