audio conundrum
Jules Watkins
audio conundrum
on Nov 8, 2011 at 8:12:50 pm
have a weird issue
using a beyer stick mic, xlr to usb into macbook pro for vo
when i start up fce and record to timeline with vo tool its fine for first 2 takes or so but then
after that when i play back new recordings its distorted and gravelly and hissy
and useless
if i quit fce then restart it goes back to normal and voice is ok for 2 - 3 takes until the issue repeats
i have tried same on a sony clip mic same happens so it's not the mic..
batts are fresh, tried 2 different usb sockets ( 1 on laptop, 1 on the 24inch monitor attached)
same occurs
all I haven't changed is the lead..
but then how come it works the first couple of times like clockwork?
i am mystified
Bob Kessler
Re: audio conundrum
on Nov 10, 2011 at 4:53:30 pm
It sounds like one of the units in your chain is defective. Things like that can be tough to track down.
Filmmaking is the art of the invisible;
If anyone notices your work you haven't done your job right.
© 2018 All Rights Reserved
