No playback from speaker on Tascam DR 100?
Ryan Atkins
on Oct 26, 2011 at 7:32:11 pm
I JUST received the Tascam DR 100 and after doing a few audio recordings I cannot hear anything from the speaker. Headphones work just fine.
The speaker switch is turned to ON, I do not have headphone plugged in, and the playback level is set to an average level.
I've read you have to be in "playback mode". I'm assuming playing mode is just when you are not recording? You can play from the home screen just fine with headphones plugged in, but nothing comes from the built in speaker.
Any ideas?
Ryan Atkins
Re: No playback from speaker on Tascam DR 100?
on Oct 26, 2011 at 9:08:52 pm
A simple reset fixed the issue. Problem fixed.
Christopher Comrie
on Mar 1, 2013 at 12:12:35 am
That's great!
I am having the same problem, but do not now how to perform a reset on the dr-100. Do you mean you went into the menu and chose "initialize"?
