TV Commercial Audio does not "POP"
Kyle Gentz
on Jul 14, 2011 at 8:50:13 pm
I'm an FCP7 Editor and an After Effects guy at the production house that I work at. I'm by far the most experienced guy with audio and I have been tasked with "Make our TV Commercial Audio "POP" more, like National commercials" We upload to dg fastchannel upload. I have been told our audio does not pop and sometimes sounds lower.
What do I need to make this happen? Our audio comes out between -12 and -6. We have an old version of Pro Tools, Sound Track Pro, Soundbooth CS5.
Alain Koffi Sessi
Re: TV Commercial Audio does not "POP"
on Jul 14, 2011 at 9:39:05 pm
Hi Kyle,
By the sound of it, you are competing with overly loud commercials. There is no universal way to do this but I will suggest to boost your signal a dB or 2 in the 2-8K range, add a small boost(Less than a dB)to the highs, and throw a Limiter on the master. Reference your final output with other commercials to see if you are still quieter.
Alain Koffi Sessi
Sound Designer
Kyle Gentz
on Jul 14, 2011 at 10:41:54 pm
We are not allowed to go over -6 with DG. -6 is considered peaking. Ill see what I can do with your suggestion.
Live, Life and the pursuit of Pixels
Ty Ford
on Jul 15, 2011 at 2:42:11 am
Hello Kyle and welcome to the Cow Audio Forum.
A combo of compression and limiting with make your audio louder by reducing its dynamic range. Different software does this differently, so I can't give you a step by step.
Regards,
Ty Ford
Cow Audio Forum Leader
Want better production audio?: Ty Ford's Audio Bootcamp Field Guide
John Fishback
on Jul 17, 2011 at 6:18:43 pm
Compressors work by setting a ratio: 2 to 1, 4 to 1, etc. What that means is with a 4 to 1 ratio the compressor only lets its audio output rise 1db for each 4db rise at the input. It's "compressing" the dynamic range of the audio. The threshold adjustment on the compressor sets the point where the compressor starts to operate. For instance, a threshold of -40db means the compressor acts on any sound over -40. That would add a lot of compression compared to -10 which would require louder audio before triggering the compressor.
Other common adjustments are attack and release. Attack sets how quickly the compressor starts when seeing audio over the threshold. Release is how quickly the compressor stops compressing after audio drops beneath the threshold. All these controls interact so setting them can be somewhat of an art.
I'd suggest starting with a ratio of 3 or 4 and experiment with different settings for the threshold. Leave the attack & release at their defaults to start. Listen carefully to the audio as there will be a point where you start to "hear" the compressor. The audio sounds crushed. This is generally not good. Raise the threshold or lower the ratio.
If you watch your meters, you'll probably see less of a swing from softest sound to loudest. That the compressor working. At times it's necessary to add output gain because as the compressor works it may lower the apparent audio level. If you Google, "using an audio compressor" a bunch of advice will pop up. Be aware that there are new Congressional guidelines governing how loud commercials can be.
Final Cut has a compressor in its audio plugins. It can work well, but its controls aren't the best. Pro Tools comes with compressors, too. You'll find them in the Dynamics category.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
