Repairing Corrupt Recording from H2
Rob Haslam
on May 20, 2011 at 5:21:47 pm
I was wondering if there was any way of repairing a recording from my H2 digital recorder. It recorded directly from the soundboard onto an sd card, but now the file is showing that there are 0kb on the sd card. Any help would be fantastic.
Rob
Bouke Vahl
Re: Repairing Corrupt Recording from H2
on May 21, 2011 at 7:23:36 am
What bytes do you want to repair if you got zero?
For a start this is IT work to get at least some data.
After that, if it is a corrupt clip, use Audacity to read it as raw data.
hth,
Bouke
http://www.videotoolshed.com/
smart tools for video pros
Eric Toline
on May 21, 2011 at 12:49:28 pm
Just suggesting possible causes. The feed from the board went dead, you forgot to push the record button, the connection into the recorder got pulled out, you had a bad cable. Can you replicate the setup again and see if the recorder works?
Eric
