audio cleaning software?
jonathan grant
on Apr 23, 2011 at 12:40:04 pm
I'm editing audio for a feature film and there is a significant amount of electronic noise on the audio tracks. We used a zoom recorder which I think is responsible for it. I tried to get the producer to invest in an amp to boost the boom mic before going into the zoom, but he opted not to get it.
There are also a few tracks where there are some various outside a/c units in the background and things like that which just sound like white noise on the track.
I've used bias soundsoap2 (never used pro) in the past, but the results are often weird and unnatural sounding.
What's the best tool for removing this type of noise under $1,000? Soundsoap pro 2? Or is there a better one you would recommend?
Bob Kessler
Re: audio cleaning software?
on Apr 23, 2011 at 4:00:59 pm
You can use a notch filter EQ for specific frequencies and a high-pass for low end rumble.
SSP Pro is okay for NR, but currently everyone is very hot on Izotope RX2. (RX2 = $300, RX2 Advanced = $1,100)
One thing to keep in mind is not to make one pass trying to get rid of everything; several passes works much better
Filmmaking is the art of the invisible;
If anyone notices your work you haven't done your job right.
© 2018 All Rights Reserved
