Good shotgun/hyper cardiod mic for video
Daniel Schultz
on Feb 2, 2011 at 1:25:25 am
I've been using the Rode Video Mic on my HMC150 as an onboard shotgun, as well as putting it on a mic stand for interviews (out of frame). It's served me fairly well, but I'd like to upgrade to an xlr and a bit higher quality with a separate shock mount (the video mic is 1/4 inch mini and has a built in shock mount which you have to use and is not very good).
Would anyone care to recommend a mic in the 200-300 range?
I'm hoping to use it for the following:
• On a mic stand, just out of frame, above 1 or 2 subjects' head for video interviews
• On board the camera for run and gun (last resort, but sometimes necessary)
First, would people recommend a hybercardiod over a shotgun (supercardiod)?
I heard that the Oktava MK 012 is a good hypercardiod for the money.
Thanks in advance for your advice.
Dan S.
Eric Toline
Re: Good shotgun/hyper cardiod mic for video
on Feb 2, 2011 at 3:35:32 am
The Oktava 012 has notorious LF handling issues. Not a mic for run & gun although if it's mounted in a good shock mount on a good boom pole on a solid stand it could work fairly well. You'll need a mixer with a LF or high pass filter to eliminate any thumps & bumps it will pick up. If you find a used AKG Blueline set with the hyper capsule & the shotgun capsule you'll be better served. Check out ebay for AKG Blueline.
© 2018 All Rights Reserved
