Antenna Tip damage
Michael Sacci
Antenna Tip damage
on Dec 11, 2010 at 6:34:14 am
I lent my Senn G2 wireless lav out and when it came back in the tip of the antenna on the transmitter has been ripped off so there is about 1/2" of bare wire now. Is this going to cause a problem and what would you guys recommend to cover the bare wire.
Jordan Wolf
Re: Antenna Tip damage
on Dec 11, 2010 at 7:06:12 am
Have you noticed any problems with the unit's RF stability? If not, I wouldn't worry about it.
Go to the hardware store and pick up some Plasti-Dip. Just dip the end of the antenna in that and let it dry.
Wolf
Michael Sacci
on Dec 11, 2010 at 8:02:04 am
Thanks, I did a quick test and it was fine, I will get that Plasti-Dip, but that will mean a lot of stuff around my house will be coated in plastic :-).
Brian Reynolds
on Dec 11, 2010 at 8:27:23 am
What about some heat shrink tube?
Thax Clave
on Dec 14, 2010 at 9:04:21 pm
If you send both the transmitter and receiver units to me I will replace the antenna.
And, I won't charge you anything.
Sennheiser charges $75 for this, I charge $00. Contact:
sendmegoodstuff@ikeepit.gyp
Michael Sacci
on Dec 14, 2010 at 10:46:36 pm
That is pretty funny. I needed a chuckle today, thanks. :-)
Eric Toline
on Dec 12, 2010 at 1:52:21 am
You can send the unit to me and I will replace the antenna with a new one. Sennheiser charges $75 for this, I charge $50. Contact:
audioetc@bellsouth.net.
Eric
