Sennheiser MKE 2-1053 to EW100 G2 ?
Jimmy Doyle
on Nov 8, 2010 at 1:39:29 am
We just got rid of our Sennheiser EM 1053-U receivers and replaced them with EW100 receivers. We kept the MKE 2-1053 mics and my question is:
Can we replace the connector with Sennheiser 99112 connectors for the EW100?
Eric Toline
Re: Sennheiser MKE 2-1053 to EW100 G2 ?
on Nov 8, 2010 at 3:33:19 am
No problem. Be sure to use a locking 3.5mm trs plug. The positive goes to the tip and the shield/ground connects to the sleeve. If you have any questions or you don't feel confident to do the conversion yourself I can do it for you. I also offer guarenteed not to fail G series output cables and G series antenna replacements.
Eric
audioetc@bellsouth.net
Jimmy Doyle
on Nov 8, 2010 at 5:20:58 am
The MKE 2-1053 has a blue wire, a red wire and an unshielded copper wire. Which wire is negative and which is positive?
Eric Toline
on Nov 8, 2010 at 12:33:10 pm
The red is positive. The blue & the copper shield get tied together at the sleeve for ground.
Eric
Jimmy Doyle
on Nov 8, 2010 at 6:36:37 pm
Thanks so much. I've got new connectors on the way.
