TASCAM DP-008 for Field Recording?
George Cahill III
on Oct 21, 2010 at 7:08:37 pm
Just curious if anyone has used, or heard of someone using, the TASCAM DP-008 for field recording...it's battery operated and just from the specs it seems to be a low-cost viable alternative for primary video sound recording.
Any thoughts or experiences out there?
Thanks.
George Cahill
MR. GREENJEANS
The All-New Captain Kangaroo Show
"If you're GREEN you GROW, If you're RIPE you ROT...Stay GREEN!"
John Moore
Re: TASCAM DP-008 for Field Recording?
on Oct 25, 2010 at 1:04:59 am
The main impediment to using this, or other "portastudio"-type recorders is that their highest recording resolution is set for music or CD reproduction: 16-bit/44.1kHz... You're going to want a minimum of 16-bit/48kHz for video sound recording.
You can use this & then up-sample to 48kHz, but it's not recommended. You'd be better served looking at something like the Fostex FR-2LE, Marantz PMD661, Tascam HDP2, or Zoom H4N.
John Moore
