Clipped Sound
Christian Clark
Clipped Sound
on Oct 8, 2010 at 9:51:56 am
Is there any way to see the sound wave in clipped sound? Basically, it was recorded way too loudly and in FCP, all I can see is a block of clipped sound rather than an actual wave of low and high points.
Thanks in advance for any help you can provide,
Christian H. Clark
City Limit Films
http://www.citylimitfilms.com
Ty Ford
Re: Clipped Sound
on Oct 8, 2010 at 1:35:09 pm
Hello Christian and welcome to the Cow Audio Forum.
You can choose to see waveforms in FCP preferences. You can also export to Soundtrack Pro.
Regards,
Ty Ford
Want better production audio?: Ty Ford's Audio Bootcamp Field Guide
Jean-Christophe Boulay
Re: Clipped Sound
on Oct 8, 2010 at 4:24:54 pm
While FCP lets you see the audio waveform in the timeline, you don't have a control over the scale of the waveform. Still, the FCP default waveform shows the complete resolution, so if you see a block with clipped tops, that is all there is to show. You can make your audio tracks taller in the timeline window to see better, but you're not generating better resolution that way. If you don't see the peaks of the waveform, it's probably because they've been chopped off by the clipping.
IHTH,
JC Boulay
Technical Director
Audio Z
Montreal, Canada
http://www.audioz.com
Peter Groom
Re: Clipped Sound
on Oct 11, 2010 at 1:29:45 pm
Have you tried re recording the audio at the correct level?
Peter
Peter
