Sound effects and music library browsing
Sacha Sojic
on Jun 4, 2010 at 8:38:20 pm
Hi guys,
I'm wondering if anyone can suggest a Mac application that facilitates browsing and searching of sound effects and music libraries. I'm finding it difficult to search through terabytes of foley and sound effects if I can't easily bring up the waveform and play out a portion of the track. For a Final Cut editor there must be something better than Apple's Soundtrack Pro to do this?
S. Sojic
Montreal, Quebec
Thax Clave
Re: Sound effects and music library browsing
on Jun 5, 2010 at 11:11:26 am
[Sacha Sojic] "I'm finding it difficult to search through terabytes of foley and sound effects if I can't easily bring up the waveform and play out a portion of the track. "
Bring up the waveform from what source?
Sacha Sojic
on Jun 5, 2010 at 1:34:39 pm
I have a complete 2Tb disk full of sound effects and music for use in my edits. I'm simply looking for an app that will facilitate searching and listening to tracks. I like to be able to rapidly see the waveform of a track so I can pinpoint hits, highs and lows. I guess I'm looking for a browsing utility for sound editors. Does that make any sense?
S. Sojic
Montreal, Quebec
cowcowcowcowcow
Antonis Tsoukatos
on Jun 5, 2010 at 4:17:07 pm
AudioFinder is relatively cheap and will defitely do what you're after:
http://www.icedaudio.com/
Soundminer is the choice of the pros. Terribly more expensive and it does a lot more than what you describe you're after. But it's there if you want to have a look
http://www.soundminer.com/SM_Site/Home.html
But for a temporary and budget-concious solution iTunes can do the trick. Launching iTunes while pressig the alt key gives you the option of working with multiple libraries. So, you could have a library for all your library tracks and separate for all the SFX. The searching facility is there and by utilising tags one can achieve a lot. But not that snappy and of course there is no waveform view option.
Sacha Sojic
on Jun 8, 2010 at 4:24:55 am
That's fantastic Antonis. AudioFinder does the trick perfectly. Thanks for the heads up.
Best,
S. Sojic
Montreal, Quebec
