Outputting Really Large Files
Cliff Baldwin
on Mar 13, 2010 at 4:31:16 pm
I'm trying to author a BluRay that would contain a large audio file - 14 gb. (44.1khz stereo)
I haven't been able to output this file as one individual chunk from Ableton or Final Cut or anything yet.
So I cut it up into pieces but am not sure if it will play back seamlessly when dropped into DVD Pro.
Any thoughts?
John Fishback
Re: Outputting Really Large Files
on Mar 16, 2010 at 5:02:38 pm
Why can't you output a large file? If you have room on your drive, FCP should easily do this. Describe your setup and workflow. However, if you're stuck with having to split things up, do a test and see if you can combine 2 of your segments inside DVDSP. Make a DVD and see if it works. A DVD's faster & cheaper than testing with Blu-ray and it will tell you if your join point works.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
Cliff Baldwin
on Mar 16, 2010 at 8:42:44 pm
I'm using FCP with 2 GIG Ram on an Intel iMac (not enough RAM?).
The final audio file is 24+ hours long. (14.4 gigs)
Chaining three pieces together in Quicktime (cutting, pasting and saving) gives me an error.
Perhaps compression is necessary. I've been trying Compression to Dolby Digital.
Hmm.
John Fishback
on Mar 16, 2010 at 9:06:36 pm
What's the capacity of your drive and how much space is left before you try to export your file? Is it an external or system drive? Have you emptied the trash?
John
Cliff Baldwin
on Mar 17, 2010 at 4:59:47 pm
External 1 Tb drive with nothing on it.
John Fishback
on Mar 18, 2010 at 9:15:01 pm
Is anything else connected to your FW buss other than the drive? How's the drive formatted?
John
Cliff Baldwin
on Mar 19, 2010 at 1:59:58 pm
It's a USB drive with nothing else attached, it came preformatted by LaCie.
Does this Quicktime error ring any bells? qtKitErrorCatchAll (1)
John Fishback
on Mar 19, 2010 at 5:19:00 pm
My guess is it's formatted FAT32 which limits your capture to 4 GB. Use the Mac Disk Utility to format it as Mac OS Extended (NOT journaled) and it should write large files. You will erase everything on the drive when you do this. If you have the option, use a Firewire port rather than usb with your Mac. Particularly with video, FCP doesn't like usb.
John
Cliff Baldwin
on Mar 20, 2010 at 3:18:52 am
OK I did all that.
Still get this error and a failed output from Quicktime with that same error message.
I've read this error is a Quicktime bug of some sort - hmm.
