OMF Question. FCP --> Pro Tools
Rocco Forte
on Jul 9, 2009 at 5:15:35 pm
In Final Cut Pro you can un-enable a clip whereby it sits in the timeline but is switched off. When I export an OMF to Pro Tools, do my un-enabled audio clips translate into the OMF and become visible in Pro Tools? I did a test using Soundtrack Pro and the un-enabled tracks DO NOT come through. I was wondering if this is the same in Pro Tools?
Thank you.
John Fishback
Re: OMF Question. FCP --> Pro Tools
on Jul 9, 2009 at 5:24:13 pm
It's the same. In FCP you can use this feature to export stems (dialogue, music, fx) instead of an entire mix.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor
ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
Final Cut Studio 2 (up to date)
Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
