How to connect Genelect monitors?
Oskari Korenius
on Apr 13, 2009 at 8:46:43 am
Hello all,
This is a very basic question. I am going to buy soon a more professional, Genelec audio monitors for my video editing machine Apple G5 with Final Cut Pro.
Because these Genelec speakers only have XLR input, I am slightly confused that what kind of audio setup should I get as the computer only has RCA audio output.
Does Active 2-way monitor mean that it does not need an amplifier as well as there is 2 input cannels?
Ty Ford
Re: How to connect Genelect monitors?
on Apr 13, 2009 at 12:16:08 pm
Hello Oskari and welcome to the Cow Audio Forum.
>>One of many good choices. Which Genelec?
>>The Genelecs want to see a line level input at that XLR. The standard unbalanced (RCA) output of a Mac tower will be a little low, but may work. To do it right, you really should have some sort of circuit to boost the RCA output to real line level. I'm using a Mackie "Big Knob" to do that now with my rig. It allows other sources to be interfaced with your monitors, which can be very helpful.
>>Active monitors, by definition, have their own power amps. I don't understand the rest of your question regarding 2 input channels.
Regards,
Ty Ford
Want better production audio?: Ty Ford's Audio Bootcamp Field Guide
Oskari Korenius
on Apr 13, 2009 at 12:57:58 pm
Thanks a lot for your reply!
I will probably go for something like the Genelec 8020APM Anthrazit model.
So I should get for example a basic 4 track mixer between the speakers and the computer?
What kind of cable should I get between the RCA output of my computer and the mixer?
Can I then plug the speaker straight from XLR output of mixer into the XLR input of the Genelec speaker?
Ty Ford
on Apr 13, 2009 at 3:53:09 pm
[Oskari Korenius] "
>>The output of the Mac will only be 2 channel, so that's really all you need, but if you do have a 4 channel around that accepts unbalanced -10 dBv (consumer line level) then you can use two of its channels. You can probably also route out of the Mac optical audio port and convert from there.
>>In general, though, I like to keep things as simple as possible and run the audio through as few stages as possible.
>>Something like this:http://www.ebtechaudio.com/lls-2des.html would do it all.
>>I use this: http://www.mackie.com/products/bigknob/ so I can have more devices routed to the monitors.
>>No special recommendation here. Not cheap, not super expensive.
>>Be sure to use balanced XLR cables between the box and Genelec inputs.
Can I then plug the speaker straight from XLR output of mixer into the XLR input of the Genelec speaker? "
>>Yes.
Regards,
Ty Ford
Ilkka Rissanen
on Apr 14, 2009 at 7:37:16 pm
Hi Oskari,
You can connect any Genelec speaker directly to your computer by using a proper RCA-XLR converter cable. If you live in Finland, you can order the cables for example from Beatman.fi. You need one cable for each speaker.
http://www.beatman.fi/product_details.php?p=132
You don't need to use any additional devices like the Mackie Big Knob because Genelec speakers will work well with -10 dBu nominal signal level used in home audio.
"Active 2-way monitor" means that you don't need external power amplifier, and that the speaker's operating bandwidth is divided into two sections: low frequencies go to the woofer, and high frequencies go to the tweeter.
Don't hesitate to ask additional questions!
Best regards,
Ilkka Rissanen
R&D Engineer
GENELEC
Ty Ford
on Apr 15, 2009 at 1:55:02 am
Hello llka,
Finland may have better electrical specs than we have in the US. My Mac audio (which is unbalanced) into my monitor system buzzes a lot due to grounding issues unless I go through some sort of balancing circuit to scrape off the noise.
While you can do it the way you suggest, there can also be a noise penalty due to the 6 dB less signal of the unbalanced Mac audio and in addition, youalso at -10 to start with rather than 0 or +4.
Regards,
Ty Ford
Ilkka Rissanen
on Apr 15, 2009 at 4:07:51 pm
Hi Ty,
Naturally balanced connection is preferred but usually Genelecs work well with unbalanced signal, too. It's easy and cheap to test it, one can always buy a Big Knob etc. later if first option doesn't work.
