can I clean up some clipping
Nelson May
on Apr 5, 2009 at 5:04:23 am
My sound guy, had a lav mic to hot and there is some slipping in my audio. I have pro tools 7 and there is a clip remover plug in. Is this any good, and can I use it to pull back the signal a bit to lessen the clipping. I also have soundtrack 2, but hardly use it. Anything in there?
G5, 1.7, 4MB RAM, 30"cine, G4, 1.6 2MB RAM, Mbox, Neumann TLM-103, FCP HD 5. Pro Tools, Adobe Creative Suite, Reason 3.0, Macromedia Studio, ProAnimator, HVX200 with Firestore v4.0
Jordan Wolf
Re: can I clean up some clipping
on Apr 5, 2009 at 6:02:01 am
Clipping can be sort of cleaned up, but it's basically in the recording for good. All of the effects used in both ProTools and Soundtrack Pro are non-destructive since they both use non-linear editing (like Final Cut Pro) and only reference the original files.
The worst thing that can happen is you don't like the result and discard that version. I've used both and they work's best to fix it a the source and make sure it's better next time.
Good luck and happy experimenting!
© 2018 All Rights Reserved
