Genelec XLR daisy chaining
Philip Fass
on Dec 5, 2008 at 2:00:29 pm
When you daisy chain two Genelec speakers through XLR, do both of them give you mono, or do they somehow separate the L/R channels?
John Fishback
Re: Genelec XLR daisy chaining
on Dec 5, 2008 at 9:31:54 pm
That set up would most likely give you a mono feed to both. The XLR is designed primarily for a balanced feed, not left and right as with some consumer audio. You'd feed each Genelec with a cable from your mixer - one for each channel, however many channels you have.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.4 QT7.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID
24" TV-Logic Monitor
Final Cut Studio 2 (up to date)
Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Philip Fass
on Dec 6, 2008 at 12:10:45 pm
I'm surprised they would market the daisy-chain feature. I can't imagine many situations where you'd want the same audio coming out of each speaker. Unless in a multi-room setup, you'd connect all the L and all the R speakers with the XLRs.
